gcole 36 #1 Posted September 4, 2012 hi everybody I was wondering if anybody knows the bearing number for the spindle on the discarge chute side on a 42 inch side discharge deck. Thanks in advance Share this post Link to post Share on other sites
pfrederi 18,709 #2 Posted September 4, 2012 There are different 42 inch decks over the years. What is the model number of yours? Share this post Link to post Share on other sites
Don1977 605 #3 Posted September 4, 2012 It could be any one of three different types. It would be best to take it apart to see what type as it may have been replaced with a newer spindle assembly. There is Double-D on the older ones with blade and pulley held with 3/8" bolts, then 3/4" keyed pulley type , then metric with 5/8" pulley with out a key. Share this post Link to post Share on other sites
tunahead72 2,552 #4 Posted September 4, 2012 (edited) EDIT: Looks like Don1977 types faster than I do... The deck model number will help a lot, but keep in mind that somebody may have replaced the spindle at some point in its history (this is on your C-120?). There's at least two spindles that I know of that will fit into the same housing, with different bearings. You can get a clue by checking the size of the nut that threads onto the top of the spindle. If you have the spindle assembly apart, you can also check to see whether the pulley and shaft are keyed. Edited September 4, 2012 by tunahead72 Share this post Link to post Share on other sites
gcole 36 #5 Posted September 5, 2012 My spindle has a 3/8 bolt holding the blade on and a key on the top shaft with another 3/8 bolt Share this post Link to post Share on other sites
Don1977 605 #6 Posted September 5, 2012 If you are right about the key at the top it's different from anything I have seen. My guess is that the 3/4" shaft has two flat sides that hold the pulley and blade. That's What we call Double-D. Here is a Double-D. Don't have a picture showing the flats on the shaft. Share this post Link to post Share on other sites
gcole 36 #7 Posted September 5, 2012 Mine has a square two piece housing with the shaft you were talking about I guess the previous owner put the key in Share this post Link to post Share on other sites
Don1977 605 #8 Posted September 5, 2012 If that a Wheel Horse spindle it's old than anything I have seen. Share this post Link to post Share on other sites
