krazy_horse 59 #1 Posted September 2, 2012 I need a belt for the 856. The one on the tractor is to short as I just can install and take it off with the starter as close to the engine as I can adjust it,even then then it is a Bear to install. Thanks,Jim Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,848 #2 Posted September 2, 2012 If you follow the parts numbers listed you end up with conflicting lengths and I don't know which is correct or a mistake WH 1583 nla Used on 6, 7, 8hp Kohler Starter generator {3Lx33" in belt chart should be 31-1/2"} Wrong? 3V315 Gates .38"x31.5" 3V315 Napa .38"x31.5" Kohler 231605 Kohler Starter generator Replaces 232613 [.41"x32.08" 36 degree]* PSB #061 Should use raw edge belt 7315 Gates .41"x32.08" 36 degree 25-7315 Napa .41"x32.08" 36 degree There is a 1/2 difference in lengths. Let us know which is correct. The belt should have raw rubber sides for a better grip and these are automotive replacements at Gates or Napa. Garry Share this post Link to post Share on other sites
krazy_horse 59 #3 Posted September 2, 2012 Thank you,This will help! Jim Share this post Link to post Share on other sites
