groundhog47 445 #1 Posted August 31, 2012 can the poly tank in any way be repaired when the welded seems leak, JB Weld doesn't hold long. the only new tank foud was pricy to me Share this post Link to post Share on other sites
rmaynard 16,836 #2 Posted August 31, 2012 Short answer is NO. Several nice used ones on eBay. 1 Share this post Link to post Share on other sites
Shuboxlover 484 #3 Posted August 31, 2012 Here's one i have listed on eBay... http://www.ebay.com/itm/200813039433?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649 Share this post Link to post Share on other sites
Tankman 3,528 #4 Posted September 1, 2012 The poly gas tank can be repaired. I've welded many a PE tank, tanks used for acids, gas, water, and many other chemicals. Best way for the average do-it-yourselfer? Use a soldering gun, melting along the seam (leak). Some welding shops carry PE (polyethylene) welding rod but, without it you can use a slice of any PE bottle (i.e.: used and washed a gal milk jug). http://www.usplastic...CFYNM4AodkDUAxA 1 Share this post Link to post Share on other sites
rmaynard 16,836 #5 Posted September 1, 2012 In my experience, the tank seam is always breached in the area of the bottom hole where the grommet must make intimate contact. Unless you are very lucky, or very good, welding the seam in that area is next to impossible while still getting a complete seal.. Share this post Link to post Share on other sites
Tankman 3,528 #6 Posted September 1, 2012 A PE bulkhead fitting, provided fits thru the gas cap, could be installed. The installed fitting can be bushed down to any size needed for the shutoff valve. That said, order one from eBay (fingers crossed). While waiting for delivery, try the soldering gun. Share this post Link to post Share on other sites
groundhog47 445 #7 Posted September 3, 2012 Thanks everyone for the help, most informative, helpful, knowledgeable folks of any place have been!!!!!!!! Share this post Link to post Share on other sites
can whlvr 994 #8 Posted September 4, 2012 i used a product on my weed eater tank,its nla so i had to repair it,its been no leaks for 3 years now,im sorry i dont remember the name but can look tommorow in the shop Share this post Link to post Share on other sites
scifi4all 6 #9 Posted September 4, 2012 I have not tried this myself and obviously a fuel tank seam is not a kayak hole, but anything is possible. http://www.instructables.com/id/Fixing-a-plastic-polyethylene-kayak-with-a-hole-/ Share this post Link to post Share on other sites
boovuc 1,090 #10 Posted September 4, 2012 I have used epoxy puttys on both metal and plastic tanks with good results. It's tough on a seam where you don't have a perfectly flat service though. Share this post Link to post Share on other sites
groundhog47 445 #11 Posted September 5, 2012 So far since 99 a patch at the grommet cutting it out and putting in a bulkhead 90 with rubber gasket has held but seam radiates out. Will try the epoxy type outside and keep biddin' on ebay. They have a couple that say for Raider that look to be correct size but appaer to have a moulded into tank nipple for fuel outlet, would one like that work. Wow on the kayak hole repair, that"s a REPAIR! Guess it might work. Would much rather try soldering iorn like Tankman than blowtorch, Ha. Thanks Share this post Link to post Share on other sites
Kelly 1,037 #12 Posted September 5, 2012 I have good gas tanks, I have new grommets and shut off valves also, I can also sell you some new fuel line with clamps to replace your old, and a new fuel filter, a complete fuel system overhaul in one stop, send me a PM. the old Raider style tank will fit but you will not have a shut off valve unless you put one in line, and many of them leak at the nipple or the nipple breaks off, Share this post Link to post Share on other sites
groundhog47 445 #13 Posted September 5, 2012 Kelly the one I looked at appaered to have been sawed or cut through the nipple also, I do have a sediment bowl with shutoff in line with new fuel line all the way. The c120 sat unused for 13 years, before that it sat about 10-15. You can prob imagine the issues that have popped up. It's back except for fuel seepage and drooling over all the WOW machines on here. Thanks>>groundhog47 Share this post Link to post Share on other sites
groundhog47 445 #14 Posted September 19, 2012 Thanks to Kelly just got a used tank and it looks GREAT, but also thanks to all else who tried to help. I took the easy way out. Got some other hard to find goodies from Kelly also and very pleased with everything! Good Day, Gerry Share this post Link to post Share on other sites
