876wheelhorse
rear lift c141
876wheelhorse
what all do i need to put rear lift on a c141 its hydro looking to put a rear blade or pull a plow with it.....
Tankman
A clevis hitch.
876wheelhorse
but what comes back to lift it and where does it hook to? any pics ???
Don1977
You will need a rocker arm that fits in the seat frame and cable with tube runs across the transmission.
Here is a picture of mine, but it has been modified because of the receiver hitch.
I moved the short bar from the right side to the left of the long bar. I also moved the lift bar on the clevis hitch to the out side with a half inch spacer.
Kelly
That is close to what you need, the same basic idea, but you need to make sure you get one for a tractor with the gas tank under the fender, like I showed you here when you picked up the 141, that rockshaft will work with the slot hitch you have also.
876wheelhorse
k i got some figureing out to do thanks
876wheelhorse
ok with the slot hitch do i even need this rocker arm? it is looking to me like just something in the middle why not just run a cable all the way back and be done with it will that work?
dbartlett1958
You could do that if you're not lifting too heavy an attachment. Otherwise you should use the rock shaft for additional mechanical advantage.
876wheelhorse
rock shaft is looking very easy to make so how do i add the lift assist spring any pics of that ?/
