876wheelhorse 46 #1 Posted August 31, 2012 what all do i need to put rear lift on a c141 its hydro looking to put a rear blade or pull a plow with it..... Share this post Link to post Share on other sites
Tankman 3,528 #2 Posted September 1, 2012 A clevis hitch. Share this post Link to post Share on other sites
876wheelhorse 46 #3 Posted September 1, 2012 but what comes back to lift it and where does it hook to? any pics ??? Share this post Link to post Share on other sites
Don1977 606 #4 Posted September 1, 2012 You will need a rocker arm that fits in the seat frame and cable with tube runs across the transmission. Here is a picture of mine, but it has been modified because of the receiver hitch. I moved the short bar from the right side to the left of the long bar. I also moved the lift bar on the clevis hitch to the out side with a half inch spacer. Share this post Link to post Share on other sites
Kelly 1,038 #5 Posted September 1, 2012 That is close to what you need, the same basic idea, but you need to make sure you get one for a tractor with the gas tank under the fender, like I showed you here when you picked up the 141, that rockshaft will work with the slot hitch you have also. Share this post Link to post Share on other sites
876wheelhorse 46 #6 Posted September 2, 2012 k i got some figureing out to do thanks Share this post Link to post Share on other sites
876wheelhorse 46 #7 Posted July 28, 2013 ok with the slot hitch do i even need this rocker arm? it is looking to me like just something in the middle why not just run a cable all the way back and be done with it will that work? Share this post Link to post Share on other sites
dbartlett1958 99 #8 Posted July 28, 2013 You could do that if you're not lifting too heavy an attachment. Otherwise you should use the rock shaft for additional mechanical advantage. Share this post Link to post Share on other sites
876wheelhorse 46 #9 Posted July 28, 2013 rock shaft is looking very easy to make so how do i add the lift assist spring any pics of that ?/ Share this post Link to post Share on other sites
