55farmall 0 #1 Posted August 30, 2012 I'm new to wheelhorse family I just bought a 520 hc with the swept toward axle . I'd like to get a snowplow for it but not really sure what all to look for . I'm going to Williams grove this weekend to look for one at the consignment sale any help one what I need to look for would be helpful . Thanks Jarrett Share this post Link to post Share on other sites
dbartlett1958 99 #2 Posted August 30, 2012 Jarrett, First off, Welcome to Red Square. Now to try and answer your question. Go to the FAQ forum and look at the Snow Plow info that is posted there. I think you will find your answer. Share this post Link to post Share on other sites
KC9KAS 4,746 #3 Posted August 30, 2012 Jarrett, Welcome to Red Square, the best darn Wheel Horse forum on Earth! Share this post Link to post Share on other sites
Kelly 1,038 #4 Posted August 30, 2012 Any long frame plow will work, does not even need the angle handle, the 520's with the swept axle all need a ext. kit, it moves the blade about 4" forwards, it is a 3 piece kit rear bracket that hooks the the back of the blade to move the mount location, a center lift relocation mount, and the angle handle that is bent backwards to clean the PTO and makes it easier to reach. The kits bring more money than the blades do, in the $200-250 range for a complete kit with out the blade so if you find one cheaper buy it. Share this post Link to post Share on other sites
Sparky-(Admin) 26,513 #5 Posted August 30, 2012 Heres pictures of my extension kit so you'll know what the extension kit consists of. This piece is what extends the plow framp forward so when angled the plow blade does not hit the front tires. This piece goes in the plow frame (where the lift attachment point is) to move the lift point back so it will still mate up with the tractors lift arm. I also have the lever used to angle the blade which has a 4"bend or offset in it to bring the angle lever back within reach of the operator, and to make sure the lever clears the PTO. Sorry, no pictures of it right now. I had planned on putting this kit up for sale when winter started showing its ugly face (Octoberish) but send me a message if your interested. Mike..... Share this post Link to post Share on other sites
Raymie 0 #6 Posted January 3, 2022 When you look at a snow plow for a forward swept like the front axle like the 520 hydros have . make sure you get the extension and the lift bar that lines it up to the lift lever and also the angle handle and angle rod a lot of the guys sell them with the blade and carriage only .Good luck Share this post Link to post Share on other sites
Handy Don 17,565 #7 Posted January 3, 2022 35 minutes ago, Raymie said: When you look at a snow plow for a forward swept like the front axle like the 520 hydros have . make sure you get the extension and the lift bar that lines it up to the lift lever and also the angle handle and angle rod a lot of the guys sell them with the blade and carriage only .Good luck You are answering a 9 ½ year old post! Gotta check the dates! Share this post Link to post Share on other sites
