frogpond 1 #1 Posted August 23, 2012 Hi. I'm new to wheel horse and just bought a 1967 877. The forward and reverse lever will not stay where I set it. It centers up into neutral when i push the brake pedal. Just trying to move it to neutral by hand, I usually can not find the center or it goes to reverse or forward. What adjustment can be made to this or is it a problem bigger than an adjustment? Thanks kevin Share this post Link to post Share on other sites
smoreau 658 #2 Posted August 23, 2012 Welcome to Red Square! The cam plate has 2 slide holders that may need to be tighter, or the cam plate may need to be replaced. They are available from your dealer or fleebay. Very come. Problem with the late 60's hydros or wheel-a-matic's In 69 wheel horse changed the design and fixed this issue. Share this post Link to post Share on other sites
frogpond 1 #3 Posted August 23, 2012 Thanks for the quick reply. Will check this out and try to find parts. Thanks again kevin Share this post Link to post Share on other sites
frogpond 1 #4 Posted August 24, 2012 Are parts available to convert my DCL to the one with the friction collar and spring? And if so is there a write up about it somewhere here? Thanks kevin Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #5 Posted August 24, 2012 :WRS: It's been a while since I worked on one, but I believe the only modification needed to install the directional control lever (DCL) assembly from a 1968 - 1977~ish model is the drilling of a hole for the tab that keeps the shaft & cone from turning. As far as the parts to convert ~ If you can't find anything locally, contact Kelly here on the forum and/or post a "wanted" ad in the classifieds. 5996 is the Toro/WH part number for the cam - and I would replace it whether you convert the DCL or not. It is a wear item - and I also recommend keeping a spare on-hand. Install it "dry". Lubricating it will cause dirt/grit to stick to it and wear it / loosen it more quickly. Share this post Link to post Share on other sites
rexman72 210 #6 Posted August 26, 2012 welcome to the site plenty of people to help you out Share this post Link to post Share on other sites
