Ed Kennell 44,693 #1 Posted August 23, 2012 .Set up my 90-1140 tranny for testing similar to squonks set-up on his post "way to flush a trans and hyd lift". The tranny just lost power in my 16 auto, so I replaced it with a 90-2046 from my Charger 12 parts horse. The tranny seems to operate OK forward and reverse. My question is with both axles locked with the yellow torque bars, if I put a scales under one bar , what torque should a good tranny develop ??? Share this post Link to post Share on other sites
pfrederi 19,801 #2 Posted August 23, 2012 I am not aware of any torque development specs. I would suggest you do a charge pump pressure test (see the sundstrand manual) Should get 70-150 psi. Is this a hydro gear or piston to piston ( I can't see the motor head in the picture to tell)? Share this post Link to post Share on other sites
Ed Kennell 44,693 #3 Posted August 23, 2012 I think it's a hydro gear. Did the pressure test. I only get 50PSI at all speeds forward and reverse and neutral. I'll go to the manual for next step. Tks, Ed Share this post Link to post Share on other sites
