Toad454 0 #1 Posted August 22, 2012 Is a condenser need on a 10 hp kohler on a 10 wheel horse Share this post Link to post Share on other sites
KC9KAS 4,746 #2 Posted August 22, 2012 Yes it is....It is connected to the negative (-) side of the coil and mounted to the engine tin so it is grounded.. The wire from the points is also connected to the same post of the coil. Share this post Link to post Share on other sites
Kelly 1,038 #3 Posted August 22, 2012 if not there or not working, it will not run very good, it may idle but will not throttle up hardly at all. Share this post Link to post Share on other sites
Toad454 0 #4 Posted August 22, 2012 It will pick up a littel then it acts like its missing Share this post Link to post Share on other sites
SousaKerry 503 #5 Posted August 22, 2012 Most points kits come with a new one and they are cheap, do yourself a favor buy the point kit your engine will thank you. :techie-eureka: Share this post Link to post Share on other sites
krazy_horse 59 #6 Posted August 22, 2012 I buy my points and condincers at my local NAPA. They come in the Kohler package. Share this post Link to post Share on other sites
Toad454 0 #7 Posted August 23, 2012 Thanks you its running again after 4 years of being neglected Share this post Link to post Share on other sites
