remchuk 0 #1 Posted August 21, 2012 Will the mower deck from a 208-4sb fit a 212-5? Thanks for the help. Share this post Link to post Share on other sites
whfan74 2,072 #2 Posted August 21, 2012 Yes you shouldn't have any issues moving from one 200 series to the other. The 212 will handle it a little bit better than your 208. As long as you aren't trying to transfer to a 265......you are all set. That is a different beast completely. Share this post Link to post Share on other sites
LDPosse 2 #3 Posted August 22, 2012 The mower deck will attach, the mounting points are the same. I'm not sure if there will be any issues with the front tires rubbing the mower deck at full lock.. Also, having a wheelbase wider than the deck will limit how closely you can cut to objects in your lawn. Share this post Link to post Share on other sites
