Save Old Iron
Onan Ignition Module Gap to Trigger Ring
Save Old Iron
No rush on this one folks. If someone has an Onan apart, I would appreciate knowing the approximate gap between the igntion module and the trigger ring. I'm trying to construct an "off the tractor" parts checker for Onan coils, triggers and ignition modules. Before I drill any holes in the test fixture, knowing an approximate gap would be very helpful.
Thanks in advance
AMC RULES
What happened, did the SOI squirrel get the pink slip?
Save Old Iron
Nothing that drastic! I was planning an SOI blowing oylmpic smoke rings based on the old icon and screwed up the animation. So I grabbed the icon I use on some of the Cub Cadet sites I frequent. The color is right, the way the cubs "split" in half for servicing of "way out" tolerances - this stuff just writes itself.
AMC RULES
I bet it's the beret. LOL
