6wheeler 670 #1 Posted August 14, 2012 Hi everyone. Just a quick question. I know we are supposed to put 10w-30 in the hydro on this tractor but, being as I don't use it for blowing snow or any wintertime use. What do you think of using 15w-40 instead? The simplicity citations I had used that in their hydros. Would it be too thick? Just a thought. Pat Share this post Link to post Share on other sites
JackC 617 #2 Posted August 14, 2012 It probably is OK bit I don't know enough to deviate from what is specifically recommended. If it acts strange for some reason you won't know if its the oil or something else. Too heavy / thick could cause some unexpected issues. It is no fun changing the oil and filter on a hydro if it doesn't work out so I would go with what is recommended. I would go with 10W-30W. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #3 Posted August 15, 2012 The Tru-Turf greens roller at work has an Eaton 1100 series hydro unit. The manual states that Mobil 1 synthetic 15W-50 can be used in hot climates, but that's mainly because of the heat build-up due to rapid & repetitive direction changes. Click here for proof. You might find it a little slow "out of the gate", but it will probably be fine once it gets up to normal operating temperature. Share this post Link to post Share on other sites
JackC 617 #4 Posted August 17, 2012 The manual for my 1996 314H specifies 10W-30W or 10W-40W premium quality motor oil. Share this post Link to post Share on other sites
Forest Road 594 #5 Posted August 17, 2012 Unless you're having issues with the trans and want o experiment I'd stick with OEM spec. I have a 314H and went with an Amsoil product. Its fine all summer and moves right along in the winter. It was either 10/30 or 10/40. Whichever the book called for. Share this post Link to post Share on other sites
6wheeler 670 #6 Posted August 17, 2012 Thanks for your input guys. The reason I ask is I have alot of 15-40 in stock. I use it in my bobcat and my pickup and diesel wood splitter so as usual I came up with yet another brilliant idea . Just thought I'd ask before it turned out like alot of other brilliant ideas I have had :scared-shocked: Share this post Link to post Share on other sites
