ricksrj58 273 #1 Posted August 12, 2012 is this the original key and switch for my 63 953? if so can i get a new one somewhere? Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted August 12, 2012 Check out Martins 1054 thread. I am fairly sure he bought a new switch for his. If its just the key you need you can get one from a Massey Fergusson dealer. Share this post Link to post Share on other sites
64s 83 #3 Posted August 13, 2012 I got a new switch two/three years ago from Ebay. Just look for a simple on/off switch - they are out there. Share this post Link to post Share on other sites
Martin 2,133 #4 Posted August 13, 2012 yeah mike, i bought a new switch. different style to that one though...... ive not seen one of the two prong switches before and not sure which models even had one. does anybody know if they are original on a 953? the switch i used on my 1054 was a cole hersee 95597 if i remember correctly..... im not sure that is the original style switch though. it has the long hencol key. and they are expensive..... http://www.elecdirect.com/product.aspx?id=13655 Share this post Link to post Share on other sites
ricksrj58 273 #5 Posted August 13, 2012 i would like to stay with the original style key/switch for this tractor.it looks like it could be the original but it did sit outside for a few years martin where did you get the new push button starter switch from,is it the same as the original ? Share this post Link to post Share on other sites
Martin 2,133 #6 Posted August 13, 2012 the push button switch i used on my 1054 is this one.... Part#: 9183 STARTER SWITCH, OFF-ON, 2STUD, THROUGH FLOORBOARD MOUNTING, SHORT STEM from here..... http://www.elecdirec...t.aspx?id=13793 looks like its yellow zinc now, whereas the one i bought was clear zinc..... Share this post Link to post Share on other sites
"D"- Man 827 #7 Posted August 14, 2012 Hello Rick, I am certain the key pictured is correct for a 953 / 1054 ignition switch, however; one way to check is if "Cole Boston 8394 Pat. Pend" is stamped on the key. The ignition switch is also stamped with "Cole Boston" on it. Mark. Share this post Link to post Share on other sites
