SolarStallion 38 #1 Posted July 29, 2012 Hi, I just bought a Charger 10 and need a belt that goes from the engine to the deck. It is a side discharge about a 40" cut. I just need some part numbers and lenghts and I should be able to figure out which one it is. Thanks, Steve Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted July 29, 2012 :WRS: More details / specifics would help tremendously to make this easier. What year is the Charger? (tractor model number?) Does the deck drive belt run straight down from the PTO pulley and under the right side of the tractor, or does it travel around any type of tensioner on the front of the tractor frame? How about the deck model number? - if the tag is there and legible. Share this post Link to post Share on other sites
SolarStallion 38 #3 Posted July 29, 2012 Hi, The model # 1 7041 s/n 544527. There is no id for the deck that I can see. Looks like the belt comes stright down and under the right side. There is no tensioner on front like on my 312-8 Thanks Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted July 29, 2012 OK - that's a 1969 Charger 10 There's a good possibility that the deck is model number 5-1422 <<< click for the parts list The PTO to deck belt is #93 on the illustration ~ which is P/N 9782 That belt is listed here as being 69" long X 1/2" wide. Share this post Link to post Share on other sites
SolarStallion 38 #5 Posted July 31, 2012 Hi, Thanks for the info! It was a big help. I will order the belt. Can't wait to try it out. I'll let you know how it works out. I have been to the last 2 wheel horse shows in Gettysburg Pa. They were a good time. Thanks again. 1 Share this post Link to post Share on other sites
