behindthebarn 0 #1 Posted July 18, 2012 I have an auto WH with a B&S twin with 36" tiller that I believe is a B-165. I'm trying to find belts and belt routing diagrams. The only ID plate I've found on the tractor has the numbers '1337' and '13585'. Do either of those numbers ID the tractor? Where would I look to find belt numbers and belt routing diagrams? I want to replace the belts on the tractor as well as to the tiller. Thanks for your help. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,518 #2 Posted July 19, 2012 Will guess the 1337 is the Julian build date - 337th day of 1981 = Thursday December 03, 1981 13585 is the serial number That should make the model number 02-16BE01 for a 1982 B-165 Twin Auto. Go to https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro Enter the tractor model number and that will bring up it's attachment list. The parts lists for them are where the belts are listed. Make sure there are not other belts listed as many parts lists are shared by similar models. Garry Share this post Link to post Share on other sites
behindthebarn 0 #3 Posted July 19, 2012 Thank you Garry. I really appreciate your explanation as well as the information. I'll try to put the info to good use. David Share this post Link to post Share on other sites
