horse junkie
Kohler K301 No Start
horse junkie
Just put a good K301 on my C120 with new solenoid and new starter have juice everywhere it is need when key is turned but I have nothing from starter. Tried different starter and different solenoid, even put brand new ignition switch in from my other C120 still nothing any help will be greatly appreciated. Tim
TT
Properly & adequately grounded?
Safety switches?
horse junkie
Yes grounded fine pto safety switch jumped clutch switch has been removed. Tractor ran fine previous to engine swap
joel_400
Does it have a seat switch? I have a c81 which is just a bit newer and that was my problem once. Just a thought. If not try jumping the solenoid and see what happens.
horse junkie
Grounded block to tractor and we have ignition not that I understand that block should already be grounded being bolted to frame. Any input?
TT
That's just the way it goes sometimes.
The original plan of grounding the battery through the bolt under the gas tank tray wasn't the best idea. A ground cable from the battery to one of the starter mounting bolts is one of the best "modifications" you could do. An additional ground wire from the battery negative terminal to a rectifier/regulator mounting bolt is also a good idea.
I've seen a few throttle & choke cables look like electric oven elements over the years. :hide:
horse junkie
Thanks Terry looks like you do learn something everyday I'll remember this one
