dazcc 0 #1 Posted July 7, 2012 Hi, hope someone can help please. I have just bought a Toro wheelhorse 227-5.I'm in the UK by the way.I'm not sure of model code as was not on when I bought it. The mower starts fine but will now not move forwards or backwards without manual pto turned on (i.e cutter deck). Does anyone have any thoughts? Daz. Share this post Link to post Share on other sites
Don1977 605 #2 Posted July 8, 2012 Sounds like the drive belt is on the PTO pulley. Share this post Link to post Share on other sites
dazcc 0 #3 Posted July 9, 2012 thanks for that im new to ride on mowers never had one before so im on a learning curve . do they print the serial number any were else on the mower do you know . thanks for that Share this post Link to post Share on other sites
Sparky-(Admin) 23,712 #4 Posted July 9, 2012 The 227-5 is a European model only I think, so I'm not sure what year it is. The model# tag went from a stamped metal tag (good!) to a sticker (bad!) with the info printed on it that eventually would fade or be torn off. If its the sticker generation machine, here in the US they were stuck to the rear fender just to the left side of the seat mount if you were sitting on it. Mike......... Share this post Link to post Share on other sites
Todd 2 #5 Posted November 10, 2012 check the pto switch its under the fuse block might be gunky stuck .. Share this post Link to post Share on other sites
Road-Track 39 #6 Posted November 10, 2012 The drive belt going to the rear of the tractor must be on the inner (closest to the engine) pulley. The outer pulley (PTO, power take-off) is for the running attachments like the mower deck. These are easy to get swapped by mistake. :WRS: Share this post Link to post Share on other sites
