RCTruckDaddy 8 #1 Posted July 1, 2012 Can someone tell me if a lift cylinder off a C-145 will fit on a C-120? Thx Dave Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted July 1, 2012 It will fit, kinda, I'm pretty sure the hoses go in at a different angle, I think the 145 they ar straight in the top the 120 they go in at a slight angle from straight up, something is in the way from them going in straight up, and it's not the hoses that are angles it's the ports in the cyl. Share this post Link to post Share on other sites
refracman 167 #3 Posted July 1, 2012 The cylinders are the same but the hoses are not. Different length and angle on the fittings for the cylinder. Come to think of it the valve might have different size fittings also. The 120 has #5 and the 145 could have #6. So yes the 145 cylinder will work. If I remember correctly one or the other should be rebuildable also. Share this post Link to post Share on other sites
RCTruckDaddy 8 #4 Posted July 2, 2012 Thanx guys. Looking to buy a C-120 but the lift cyl leaks. The cyl was partially extended and let sit so it is rusted pretty bad. Had a line on a replacement but wanted to make sure it would fit. Share this post Link to post Share on other sites
