BairleaFarm 340 #1 Posted July 16, 2008 76 C160 or a 73 4speed with a 10hp kohler? Which one do you think has more pulling power? Share this post Link to post Share on other sites
BPjunk 184 #2 Posted July 17, 2008 David, The weight would be the deciding factor between these two models ...... ifn's every other factor is equal. <_< The C-160 will weight a few pounds more with some extra HP ..... soooooooo if the traction is the same the C-160 should be the better puller. :banana: Wild Bill in Richmond, Va. Share this post Link to post Share on other sites
nylyon-(Admin) 8,304 #3 Posted July 17, 2008 Well, is that C-160 an automatic or 8-speed? Share this post Link to post Share on other sites
Deere Hunter 54 #4 Posted July 17, 2008 you havnt said if the C160 is an 8-speed or hydro. If its an 8speed I would say the C160 is your best choice by far. I have pulled a C160 8speed in the stock class and when it is setup right it can be a very competitive tractor Share this post Link to post Share on other sites
BairleaFarm 340 #5 Posted July 17, 2008 Its a hydro with turf tires. Ive got soso ags on the 73 Share this post Link to post Share on other sites
