BairleaFarm
Which has more HP at the wheel?
BairleaFarm
76 C160 or a
73 4speed with a 10hp kohler?
Which one do you think has more pulling power?
BPjunk
David,
The weight would be the deciding factor between these two models ...... ifn's every other factor is equal. <_< The C-160 will weight a few pounds more with some extra HP ..... soooooooo if the traction is the same the C-160 should be the better puller. :banana:
Wild Bill in Richmond, Va.
nylyon
Well, is that C-160 an automatic or 8-speed?
Deere Hunter
you havnt said if the C160 is an 8-speed or hydro. If its an 8speed I would say the C160 is your best choice by far. I have pulled a C160 8speed in the stock class and when it is setup right it can be a very competitive tractor
BairleaFarm
Its a hydro with turf tires. Ive got soso ags on the 73
