bean 85 #1 Posted June 27, 2012 I picked up a snowblower that is in really good shape. the bearings are tight and just has a little paint flaking. it is a 36" for a tach-a-matic. no model number on it. I got it fairly cheap, so if I have to do some fabbing, I can. the good: the small sprockets and pulleys are in great shape. the bad: the main auger sprocket is worn about 50%. the points of the teeth are worn down. suprisingly, I cant get the auger to skip or even rock back and forth much.. how far can the sprocket be worn, and still be usable? I am pretty confident I can cut off the and weld on a replacement sprocket if so, I would like to do it before I need it. :) Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted June 27, 2012 I know guys have bought new gears from places like McCarr, or Fastenal, and replaced them, I buy my little drive gears from Fastenal, not sure on what the big gear cost but I'm sure it's not to bad. Share this post Link to post Share on other sites
bean 85 #3 Posted June 27, 2012 :text-thankyouyellow: Share this post Link to post Share on other sites
bean 85 #4 Posted June 27, 2012 kelly, I found a source for the sprocket. is it a 40 ansi chain? or 35? I went back through a few searches, and it looks like it is 40. Share this post Link to post Share on other sites
can whlvr 994 #5 Posted June 28, 2012 pretty sure its #40,and some guys have replaced the main gear,it would be worth it if y can do it yourself Share this post Link to post Share on other sites
bean 85 #6 Posted June 28, 2012 I agree. after switching the main sprocket, it should be in good shape. it is only a 36", but maybe that will be a blessing with just 10hp. Share this post Link to post Share on other sites
