green400 2 #1 Posted June 24, 2012 FREE !! no mower deck, or other impliments.. nice straight frame... has a 8hp Tecumseh... that doesn't run.. looks like a cracked crank case.. and possible cracked jug... carb missing parts,.. spark plug hole stripped... seeing as tecumseh isn't in the small engine biz anymore.. we are currently looking for a replacement ... I'm sure the topic has come up... but what are some "replacement" options? Thanks D Share this post Link to post Share on other sites
546cowboy 302 #2 Posted June 24, 2012 :text-worthless: and a Kohler of course. Although maybe a Carrol Stream 6.5 knock off would look good in there. Tecky's are hard to find in good shape. Share this post Link to post Share on other sites
Sparky-(Admin) 23,804 #3 Posted June 24, 2012 Are you looking to go with a vintage motor or would you go modern? I went with a Honda 5hp on a 656 and its fantastic. Starts easy, runs perfect everytime and is quiet as a church mouse. If not find a nice little Kohler K-91 for it. Mike............. Share this post Link to post Share on other sites
Jake Kuhn 1,581 #4 Posted June 24, 2012 :text-worthless: Share this post Link to post Share on other sites
AMC RULES 37,235 #5 Posted June 24, 2012 Are you looking to go with a vintage motor or would you go modern? I went with a Honda 5hp on a 656 and its fantastic. Starts easy, runs perfect everytime and is quiet as a church mouse. If not find a nice little Kohler K-91 for it. Mike............. ...and If you are looking for a replacement motor, I'd only consider using the Honda brand. Share this post Link to post Share on other sites
Kelly 1,033 #6 Posted June 24, 2012 That is a short frame tractor and the dash tower is not as tall as a long frame, so if you want to put a 10hp or bigger Kohler in it, you will need some special parts from other tractors like the 1055, 1045 or 1075, or you will have to cut the hood alot, a 8hp Kohler will be a bolt in and you can use common stock parts to do it, from many models of tractors to name a few 855, 856, 877, commando 8 and a number of others, or use a honda or clone, and the little diesels are getting popular Share this post Link to post Share on other sites
green400 2 #7 Posted June 24, 2012 Kohler K91... hmmm... I just may have a line on a smaller kohler... as soon as my boy uploads the pics ...we'll post them... thanks d Share this post Link to post Share on other sites
Kelly 1,033 #8 Posted June 24, 2012 The K91 is only 4hp I'd shoot for a K181 8hp 1 Share this post Link to post Share on other sites
green400 2 #9 Posted June 24, 2012 7 hp Wisconsin.. elec... Might make a good canidate... what are your thoughts? 2 Share this post Link to post Share on other sites
SousaKerry 503 #10 Posted June 24, 2012 Nice. Not sure about the mounting but those are nice heavy duty engines should last dang near forever. Share this post Link to post Share on other sites
Kelly 1,033 #11 Posted June 24, 2012 I can say you will have no hood when your done cutting it to fit around the engine. Share this post Link to post Share on other sites
green400 2 #12 Posted June 24, 2012 oh boy... not into cutting stuff... was hoping this lil Wis would kindda drop right in... sans a little gas tank bracketry modifications.... hmmmm... gonna have to get a few measurements.. .. Share this post Link to post Share on other sites
green400 2 #13 Posted June 24, 2012 ' '66 Wheelhorse 6 0 6 Share this post Link to post Share on other sites
Kelly 1,033 #14 Posted June 25, 2012 That is a clean tractor, I would not even restore it, I had a clean 656 same tractor just elect. start I swapped in a 8hp Kohler with all the right parts and I bet no one can tell it is not the orig. engine, the patina on the engine even matched the tractor, now I have a 856, and I love the little thing, I even found the correct ID tag so no one can tell. Share this post Link to post Share on other sites
green400 2 #15 Posted June 25, 2012 the 7hp Wis was a little too tall and a lil too long... nice clean lil engine but just won't fit without modifications..... and it has auto choke.... bummer... Share this post Link to post Share on other sites
MarkPalmer 81 #16 Posted June 25, 2012 Too bad the Wisconsin won't fit easily. A lot of those Wisconsins, even the smaller HP ones, have forged steel cranks and rods and were incredibly tough small engines. -Mark- Share this post Link to post Share on other sites
AEarlCheal 1 #17 Posted August 7, 2012 I have a WH which has been painted over (not a restoration). I found the data plate under the dash panel. The transmission has a high/low range, which makes it an 8 speed. It has no engine or attachments. The markings as I can best tell are: 1 605T 695278 The research I have done indicates the 605 was only a 4 speed. I wonder if the T indicates an 8 speed transmission. Does anyone know? Share this post Link to post Share on other sites
Duff 206 #18 Posted August 9, 2012 Green400, the last thing in this world I would to do is chop up that tractor in any way - it's in way too good condition for its age to be butchered. I'd vote with the rest of the guys here who say find an engine that fits without major mods and you'll have a rel gem! And you got it for free? OMG!!!!! Duff Share this post Link to post Share on other sites
