Wheel-N-It 2,976 #1 Posted June 12, 2012 I recently installed some Simplicity brand wheel weights (from the 1950's) on the rear of my 312-8, and liked them so much I thought I would put some wheel weights on my 417 to try to keep the rear tires from scuffing up my front yard when taking an uphill offcamber turn while mowing. I have a bunch of barbell plates that fit the olympic size bar ends, and discovered the 15kg / 33lb barbell plate will fit the 12inch rear wheel perfectly. Anyway, the next thing I discovered is the things are made out of powdered iron, and I cannot get a drill bit through it. My question is has anyone here tried to drill through powered iron and been sucessful? If so, how did you do it? I don't want to spend more on drill bits than I would spend on a set of wheel weights, so should I abort this idea and try something else? Also I don't want to rig up something to make the weights work. I want to bolt them on the way they should be and use proper size carrage bolts to hold them to the wheel. So from experience, what do you guys think? Thank you for your input:) Van Share this post Link to post Share on other sites
AMC RULES 37,185 #2 Posted June 12, 2012 Good idea Van. :wwp: Share this post Link to post Share on other sites
CRE1992 135 #3 Posted June 12, 2012 I have 2 sets of simplicity/allis weights that I am looking to sell!! pm me ! Share this post Link to post Share on other sites
Wheel-N-It 2,976 #4 Posted June 12, 2012 Good idea Van. Thanks Craig. I thought it was a good idea too, until I smoked two perfectly good drill bits .............. but hey it did give me something to write about tonight CRE, PM on the way! Share this post Link to post Share on other sites
312Hydro 474 #5 Posted June 12, 2012 Did a Google and found this- http://www.mytractorforum.com/showthread.php?t=113505 .They used carbide tipped masonry bits. Share this post Link to post Share on other sites
Wheel-N-It 2,976 #6 Posted June 12, 2012 Thank You for the research Rich. I found this too, and it left me thinking I may be better off just buying some weights and bolting them on. I think I had rather do that and have the fab time for other stuff. One thing I found here at RS is someone used 5inch pipe flanges for weights. Without going back to re-read the post, I think the 5inch flanges weigh about 25puunds each, and is predrilled to match the wheel. I may run across some, and will grab a couple to see for myself. I am going back to edit my first post here. I should have said " POWDERED IRON not POWERED IRON" . sorry for the misspell. Van Share this post Link to post Share on other sites
IBleedRed 24 #7 Posted June 13, 2012 Check these out, I found them while looking up weights for my puller. Search for "GARDEN TRACTOR WHEEL WEIGHTS SYSTEM - UNIVERSAL MOUNTS" on ebay. Share this post Link to post Share on other sites
can whlvr 994 #8 Posted June 13, 2012 could the bolts be welded to the weight and then bolt it on with the nuts on the inside? Share this post Link to post Share on other sites
massey 119 #9 Posted June 13, 2012 I used cast iron barbell weights for the rear wheels of the C160 and had no trouble drilling through them. If the iron in your weights is that hard, try a USA made cobalt bit. Share this post Link to post Share on other sites
Wheel-N-It 2,976 #10 Posted June 13, 2012 I'll try to find one of those cobalt bits, and if I can, I'll try to do the drilling in a press. Not giving up on finding a good set of weights though:) Share this post Link to post Share on other sites
JUSS10 250 #11 Posted June 13, 2012 Those universal mount setups on ebay are exactly what i had in mind when i read this title. i may have to build myself a set of those! Share this post Link to post Share on other sites
Coadster32 793 #12 Posted June 13, 2012 Drill press is the way to go, as is cobalt, (M42). The rpm on the hand drills is just way too fast,(burning up drill bits). A little liquid to keep things cool would help out as well. Good luck, it's a great solution. Share this post Link to post Share on other sites
bewford 21 #13 Posted June 14, 2012 I also drilled out some barbell weight plates, with no trouble. slow and steady wins the races Share this post Link to post Share on other sites
Wheel-N-It 2,976 #14 Posted June 15, 2012 I may have some masonary bits that size. If I do, I will try drilling using a drill press with lots of cutting oil. My problem though is time. I have so much grass here to cut (and run the weedeater), that mowing takes up most of my spare time and energy. What I really need to do is figure out a way to clone myself Then I could get some work done around here! Share this post Link to post Share on other sites
312Hydro 474 #15 Posted June 15, 2012 What I really need to do is figure out a way to clone myself Then I could get some work done around here! Funny, That's what my wife tells me! :ychain: Share this post Link to post Share on other sites
maxed500 10 #16 Posted June 22, 2012 quick, but very ugly, Turn arc welder on highest setting and melt hole. Will look very nasty unless you grind splatter smooth and washer over hole. Share this post Link to post Share on other sites
over60pirate 24 #17 Posted June 28, 2012 I did that on my 414-8 I used a 1/2" x 2" x (length that fit inside wheel) bar of steel, and welded a 1" barbell bar to it. The steel bar is bolted to 2 holes in the wheels. It's a lot easier removing weights with this setup, than oem ones. Just slide the weights on. The picture shows a 50# plate. Behind it are, smaller plates that fit inside the wheel. Total weight on each wheel is 85#'s I am also making a bar mount for the front of the tractor to hold weights, when needed. I have to mow the sides of ditches in front of my property, and the 170#'s of weight helps keeping the shiny side up! 1 Share this post Link to post Share on other sites
over60pirate 24 #18 Posted June 28, 2012 I should have added, that before I found te 50# plates, and was able to cut the bar length down, it was a real chin grabber. Especially when the weights were off. I leave the weights on all the time, for ditch cutting, and for use with the plow/bucket. Share this post Link to post Share on other sites
