Will G
possible bad solenoid on c-111?
Will G
Went to start my c-111 the other day to run it for a few to keep the battery charged while it is waiting on tranny work and it would not crank when I turned the key to the start position. All the safety switches have been disabled on the tractor so I know it is not a safety switch issue. When I turn the key I can hear the solenoid clicking but the starter is not activating. The starter was replaced in the fall with a genuine briggs and stratton starter. I can use a jump pack and activate the starter and it will crank fine. Agreed with a bad solenoid?
Ken B
Will, try jumping the solenoid with a jumper wire. If she turns over more than likely bad solenoid. The contacts get corroded in there.
Wheel-N-It
Agreed.
JackC
I have seen it all, bad solenoid, bad switch, bad connections, weak battery, battery terminals.
Often cleaning all contacts solved the starting issues for me.
A volt meter is very helpful to isolating to the problem.
Some starters need a full 12+ volts to spin the engine, I have seen where 11.5 would not do it on some.
Start from the battery with clean terminals and work out from there looking for 12v+ along the way.
Or measure the voltage at the starter and work back.
Will G
I have power coming out of the solenoid to the starter and now it works. I guess I will replace the cable from the solenoid to the starter as it seems kinda iffy.
Kelly
Be sure you have a good ground on the engine and the solenoid.
SAM58
Agreed.
Agreed again...
