Kelly 1,039 #26 Posted June 15, 2012 Before 90 they had the standard 7" rims like other WH's Share this post Link to post Share on other sites
Chevydave 25 #27 Posted June 15, 2012 Bought a new set of 8.5" wide rims and 10.5" wide 4-ply Carlisle turf savers for the back of my '89 416-8. I have a 42" side discharge deck and the deck wheels rub on the side walls of the tires enough to make a mark. It's pretty bad with the deck in the "up" position you can see the deck wheels rotating. Might have to put chains on them and use them with the snow blower. A little disappointing but they do look great. Share this post Link to post Share on other sites
luvmyWH 4 #28 Posted June 15, 2012 I have a 48 deck and they r close to wheels on it on mine. Share this post Link to post Share on other sites
AMC RULES 37,261 #29 Posted June 15, 2012 Bought a new set of 8.5" wide rims and 10.5" wide 4-ply Carlisle turf savers for the back of my '89 416-8. I have a 42" side discharge deck and the deck wheels rub on the side walls of the tires enough to make a mark. It's pretty bad with the deck in the "up" position you can see the deck wheels rotating. Might have to put chains on them and use them with the snow blower. A little disappointing but they do look great. Maybe you can adjust the deck mounts a little to find the room you need? Share this post Link to post Share on other sites
Chevydave 25 #30 Posted June 15, 2012 I think if I could find a sholder bolt with loner thread section I could add a couple of washers and gain a 1/4" or so. I used the standard shoulder bolt and I got 2 semi-thick washers on while still having enough thread to go fully into the nut. It wasn't enough to clear the tires but I probable got an 1/8" a side, need at lease another 3/8 to 1/2" a side. I was suprised to hear it was still a problem with a 48" I thought that was my answer. Share this post Link to post Share on other sites
Arrowhead 0 #31 Posted June 15, 2012 That looks awesome!!! :handgestures-thumbsup: Share this post Link to post Share on other sites
luvmyWH 4 #32 Posted June 15, 2012 here are a couple of pics of how close my tires are with a 48 inch deck. Thats with deck lowerd.With it up its really close but doesnt rub the tires anywhere. Share this post Link to post Share on other sites
whc160 80 #33 Posted June 16, 2012 Here is my C-160 with 23x10.50x12 Tru Power on the rear & 16x7.50x8 Truf Masters on the front. The rims had craftsman tires on the went I got them. Wanted to keep the wheel base close together because I only have a 42" snow plow. But there is only a half inch between the tire & my tiller belt. I have not had a deck on this tractor since I put the tires on. Share this post Link to post Share on other sites
