608KEB 829 #1 Posted June 9, 2012 The bypass valve on a B-100 I bought a few months ago will not free up. I have been spraying PB blaster on it every other day for the last 2 months. I still have had no luck. Any suggestions? KB Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted June 9, 2012 I've used heat on a couple, it is best to use a torch with a heating tip so you can put lots of heat fast to one spot, if you use a small say butane torch it takes forever to heat it up and the heat spreads farther the longer you heat. Share this post Link to post Share on other sites
608KEB 829 #3 Posted June 9, 2012 I was afraid of damaging something on the inside. But I will try that. Can that screw come all the way out? Share this post Link to post Share on other sites
