Challenger 27 #1 Posted June 8, 2012 I've got a used #78364 Recycler deck and I wonder if I can "convert" it to a standard side-discharge deck? Are the under deck "mulching" parts removable? I've never studied the deck and I'm a couple hundred miles from where the deck is, at our cabin. Is it a matter of just removing some screws and bolts and taking out a couple of parts? If the mulching stuff is removed will the deck perform like a regular side discharge deck? All ideas, thoughts, opinions and first hand experience requested and appreciated. Thanks. Share this post Link to post Share on other sites
mattd860 162 #2 Posted June 8, 2012 I have the same deck and recently converted it to a regular side discharge deck. So the answer to all your questions is YES. All the baffles are easily removable via a few carriage bolts. Make sure you re-install all the bolts after you remove the baffles otherwise you will have a bunch of small holes in the deck. With the baffles removed, the deck will operate and perform no differently than a standard side discharge deck. Share this post Link to post Share on other sites
nylyon-(Admin) 8,134 #3 Posted June 8, 2012 Can't speak for the 5xi, but on my 42" rear discharge, the baffles come out, but the blades are different when using the recycler. Share this post Link to post Share on other sites
Challenger 27 #4 Posted June 9, 2012 Thanks for the responses. HOW are recycler blades different from the standard blades? Different shape? Will the recycler blades not cut as well without the recycler baffles? Thanks. Share this post Link to post Share on other sites
