blake616 4 #1 Posted June 7, 2012 I have a 1993 416-8 that the oil drain pipe is loose from the engine block. It is not leaking yet, but just need to tighten. Obvioulsy, I can't get a pipe wrench on channel locks on the pipe to tighten. I'm thinking I need to unbolt the engine from the frame to get access to the pipe? Just wondering if anyone has any ideas how to proceed? Thanks...Richard Share this post Link to post Share on other sites
JackC 617 #2 Posted June 7, 2012 Removing the engine from the tractor appears to be the only way to have access to tighten the pipes. Share this post Link to post Share on other sites
AMC RULES 37,254 #3 Posted June 8, 2012 Is there room for a longer drain pipe that you can get a wrench on? :WRS: Share this post Link to post Share on other sites
Kelly 1,037 #4 Posted June 8, 2012 Most engines on WHs you have to unbolt the engine and tilt it to turn the fitting, I have a few I need to do, one of my 520s I turn by hand so it points up and when I change the oil I turn it down, it seeps some but I really need to unbolt the engine and fix it. Share this post Link to post Share on other sites
