watercross 0 #1 Posted May 29, 2012 Does a 310-8 have tubes in the front tires? Left front tire is flat (has slow leak) and when I look up part diagrams for tires it has "OPT" next to the tube. Also when I look up the part it says $59.20 for a tube - that is Crazy. I can tell that the tire does have a small crack in it when it is flat. Tire is about the same price. So do I need a new tire, just a tube or both. Does Tractor supply or stores like that sell tires this size and that price is crazy for a tube and tractor tire. Also Share this post Link to post Share on other sites
Kelly 1,035 #2 Posted May 29, 2012 Yes TSC has tires and tubes, tires your size about $35-40 tubes about $10-12 if it is tubed when it is flat you will be able to push the valve stem in to the rim, if it does not have a tube the valve stem will be pretty solid in the rim, I don't think factory they where tubed. Share this post Link to post Share on other sites
