kpthorsefan 34 #1 Posted May 27, 2012 Hi all, I have what i think is a 42" cutting deck and need to replace the blades, i cant find any id on the deck to help get the part numbers for the blades, any ideas ? Here is the deck. Share this post Link to post Share on other sites
kpthorsefan 34 #2 Posted May 27, 2012 Hi, This is one of the blades i took off with a part number on it , but still cant come up with anything so it might not be the right blade . Share this post Link to post Share on other sites
darren 49 #3 Posted May 27, 2012 I don't think I've seen blades like that before. That number also looks unusual too. I think you'll want 106636 for a 42" SD deck; Toro-Wheelhorse - 106077, 106636 Description: 13-7/8" Standard Side Discharge Blade Requires 3 for 42" cut, side discharge Length: 13-7/8" Center Hole: 3/4" Width/Thickness: 200-203 If you're looking to sell the deck at any point, please let me know, I'm on the lookout for one! :) Share this post Link to post Share on other sites
kpthorsefan 34 #4 Posted May 27, 2012 I don't think I've seen blades like that before. That number also looks unusual too. I think you'll want 106636 for a 42" SD deck; Toro-Wheelhorse - 106077, 106636 Description: 13-7/8" Standard Side Discharge Blade Requires 3 for 42" cut, side discharge Length: 13-7/8" Center Hole: 3/4" \Width/Thickness: 200-203 If you're looking to sell the deck at any point, please let me know, I'm on the lookout for one! Thanks for that darren , looks like you could well be right.. :) Share this post Link to post Share on other sites
can whlvr 994 #5 Posted May 27, 2012 i just bought a set yesterday at the dealer,60 bucks plus tax,i only paid 50 bucks for the tractor with the deck,so i guess i can splurge on new blades Share this post Link to post Share on other sites
kpthorsefan 34 #6 Posted June 16, 2012 Got the new blades today, the wrong blades must have been fitted in the past... Share this post Link to post Share on other sites
darren 49 #7 Posted June 16, 2012 wow, that's quite a difference! I guess the PO must have fitted the nearest equivalent rather than bother to source a Toro blade.. Share this post Link to post Share on other sites
can whlvr 994 #8 Posted June 17, 2012 she will cut much better now as the angle creates lift for the grass Share this post Link to post Share on other sites
tommyg 154 #9 Posted August 22, 2012 I bet the original blade was designed for a recycler deck. The blades need to lift the grass, but not discharge it, thus the lower angle. Just a thought. Share this post Link to post Share on other sites
