SFF in England
Belt part Nos needed
SFF in England
Hi recently got an 8HP C-81 serial No 91-08k8-91. I need to replace the belts, how can I find the part nos please
Anglo Traction
Firstly , Hi SFF and :WRS:. Had to direct you to this section because the Shout Box would not be suitable for the reply length as it is not a straight forward answer.
The Model number you have is not traceable, as it is on a Tractor that was assembled in Belgium (no offence Guys over the Channel). So we have to match it to the Proper U.S Model number which is 91-08K801 in order to check it on Toro's Site for Parts and Manuals searches.
Having done that, we have more dilemmas, as the Toro site quotes 2 different Drive Belts for it !. They also may be incorrect for your Tractor.
My suspicion is that your Drive Belt should be Part Nbr 7473 which is 81.95 inches long (measured around the outer circumference). So you can check yours to varify that.
I can E-mail you a Toro Belt Chart with Highlights on the relevent pages that apply (or could) to your Tractor. Also if you know your Mower Deck model Number , you can check the Chart to ascertain the Size Belt you may also need for that .
You can send me your Email add via a Personal Mssge if you wish.
Hope this helps.
Oh and by the way, your Tractor was probably built in 1979.
Regards.
