hpeeler 0 #1 Posted May 21, 2012 I have a 50" mid mount grader blade that goes on my 416-8, both are 1989 models. I have misplaced the manual for the blade but the numbers on it are 0750BM03 70114. I don't know which one is model # and which one is serial #. I am in need of the lift bracket that attaches to the litft on the tractor and the middle of the blade. It's about 6-8 inches long and offset. If anyone has one for sale or that they could measure for me and/or send pictures I would appreciate it. It wouldn't be hard to make on if I knew the dimensions. Thanks Share this post Link to post Share on other sites
312Hydro 474 #2 Posted May 21, 2012 Here's the link to your blade on Parts tree. http://www.partstree.com/parts/?lc=toro_consumer&mn=07-50BM03%2C+50%22+Grader+Blade%2C+1990&dn=810754R1-54R10005-0001 i don't have a grader blade but maybe it would help you identify your part so someone else can help you. Share this post Link to post Share on other sites
Forest Road 595 #3 Posted May 22, 2012 You can use a straight piece of steel with holes 11 or 12" apart. Use 1 1/2" x 1/8" is plenty. You can use bolts or pins from a hardware store. Share this post Link to post Share on other sites
