rondo 0 #1 Posted July 13, 2008 Both listed locally (sort of) and about the same price. B-100 is a 1974 - hydro, Commando listed as 1972 - 3 speed. Have only seen pics - look to be in similar condition. Both have the mower decks with them and the B-100 has a plow/dozer blade. Any pros/cons on either of these models? Is one considered a better or more versatile tractor than the other? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted July 13, 2008 The B-100 is probably more "user-friendly" and has a much heavier built engine with 2 more horsepower. Unfortunately, the extra horsepower will be absorbed by the hydro transmission. Make sure you "work test" the hydro -- meaning get it up to operating temperature and try to pull something with the tractor or climbing a grade. Listen for any LOUD whining noises and see if you notice any slippage. A lot of it will depend on what you want to do with the tractor you purchase. Share this post Link to post Share on other sites
rondo 0 #3 Posted July 13, 2008 Thanks, TT. I've been looking for awhile, and I'll probably be looking to push a little snow, maybe break some ground at times. I have two tractors for cutting but I really want a WH for some of the other tasks. I've been trying to hook up with some owners who have C series (to hopefully buy), but we can't seem to make the connection. I think I'll go test drive these two and see how they do. Thanks Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted July 13, 2008 The B-100 will have the 12" rear wheels which are easier to get weights and chains (and tires) for. Although they aren't exactly a C series, they are very similar in most respects, and parts are out there if you need to make repairs. The B-100 also has the ability to comfortably run a 42" mower deck, and since it has the dozer blade included in the deal, you should be all set for snow removal. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,752 #5 Posted July 13, 2008 I agree with TT on the B-100. But follow his advice and test drive the hydro. If it tests out okay, and the engine runs good, I would go with the B-100, especially you want one to push snow and it has the snow plow already. B) Share this post Link to post Share on other sites
Nick 13 #6 Posted July 15, 2008 I gots the bad memory here but in the B vs C post it was said 74 and 75 B-100 auto had the medium frame? If the B-100 auto has a medium frame it would only handle the 36" deck same as the Commando 800. I realy liked my commando 800. And if the lighter duty 4 speed fails it was an easy swap to an 8 speed. I installed 3 rib tires on the front and used it with a mid grader a lot. Share this post Link to post Share on other sites
