BairleaFarm 344 #1 Posted July 12, 2008 Anyone put a loader on a c160? Im sure they have but cant seem to find a thread on it? If you know where pictures are hiding please let me know. Thanks David Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #2 Posted July 13, 2008 Back about a year ago, Eldon had a C-160 with a loader. Here's the link: http://www.wheelhorseforum.com/index.php?showtopic=104 Share this post Link to post Share on other sites
Nick 13 #3 Posted July 13, 2008 This tractor was at the 2003 PA show. If not a C-160 its close and has 26-12-12 tires and a KW loader. This is also from 2003. Its a C-160 with WHeel Horse loader. Share this post Link to post Share on other sites
BairleaFarm 344 #4 Posted July 13, 2008 Do they use a hydrostatic drive or and separate pump to run the hydrolics? Share this post Link to post Share on other sites
Nick 13 #5 Posted July 13, 2008 I believe all loaders used on Wheel Horse tractors use a seperate pump. Most newer loaders mounted the pump on the loaders subframe but some had it on the side of the tractor frame or in front. Share this post Link to post Share on other sites
KyBlue 655 #6 Posted July 13, 2008 The second C160 pic posted you can see the pump stickin out kinda.. Share this post Link to post Share on other sites
Nick 13 #7 Posted July 13, 2008 This picture shows the pump placement on an Ark loader just behind the PTO. The KW pump would be on the loader sub frame just below the PTO. Found an old picture of the Ranger. Pump is mounted much the same as a factory KW setup would be. Just direct drive no clutch. Share this post Link to post Share on other sites
C-Series14 15 #8 Posted July 14, 2008 1979 C-161 8-speed with a 1979 WH FEL...On the back is a 1977 18 Cu. Ft. dump cart...BIG cart! Attached Image Share this post Link to post Share on other sites
