farmer 1,078 #1 Posted May 12, 2012 Today was a beautiful day weather wise, but it's been really wet for the past few weeks, so I thought I'd make the best of it and do a spot aeration. I loaded the weight tray up with six 56lb weights so 336lbs total, which combined with the moist lawn ment the 512 struggled a bit for traction. So I left the steeper areas and did those later with the 312 with ags. I haven't aerated for quite a while so I think I done some good today. Some pictures; Share this post Link to post Share on other sites
AMC RULES 37,211 #2 Posted May 12, 2012 So that's how it's done, huh? Seems like you've got some serious weight on there Rex. :text-coolphotos: Share this post Link to post Share on other sites
Horse'n Around 22 #3 Posted May 12, 2012 Yikes, just looking at the teeth/spikes on that gives me the heebie jeebies !!!! John Share this post Link to post Share on other sites
bowtiebutler956 650 #4 Posted May 12, 2012 That is a beautiful lawn you have! You definitely have the right equipment for taking care of it. Matt :flags-texas: Share this post Link to post Share on other sites
Don1977 605 #5 Posted May 13, 2012 I punched some holes a couple months back. That is 5 - 8"x12"x16" 75% solid fire blocks at 75 lbs. a piece. I had no trouble pulling it, but it does pull better when I have 80 lbs. of wheel weights in each rear wheel. 1 Share this post Link to post Share on other sites
farmer 1,078 #6 Posted May 14, 2012 I think it could be said, you double punched Don. :) Share this post Link to post Share on other sites
