Ed Kennell 43,914 #1 Posted May 8, 2012 Can the lift cylinder be rebuilt ?? It is a welded cyl . Which end has to be cut? Share this post Link to post Share on other sites
Trouty56 567 #2 Posted May 9, 2012 The weld towards the working end.  Once the weld is cut it slides apart.Cutting the weld is easy with a lathe.  New seals are easy to put in. Welding it closed is hard.  sent via mobile.... Share this post Link to post Share on other sites
Ed Kennell 43,914 #3 Posted May 9, 2012 Tks for the info Bob. Any advice on the reweld?? Share this post Link to post Share on other sites
Trouty56 567 #4 Posted May 9, 2012 The guy who did for me had a motor driven lathe that he practiced with a pipe till he got it right. Then he welded it and dunked it in water right away. If i were you id look for a rebuildable cylinder. sent via mobile.... Share this post Link to post Share on other sites
Ed Kennell 43,914 #5 Posted May 9, 2012 Tks, I just checked ebay. ed Share this post Link to post Share on other sites
