Dynaformer 0 #1 Posted May 8, 2012 I have two Wheel Horse Tractors, mower decks and snow blades. Are there Commando 8's? Please help identify these tractors model 867 s/n 364883 Model 857 s/n 291215 Thanks, Dynaformer Share this post Link to post Share on other sites
CasualObserver 3,411 #2 Posted May 8, 2012 If you are asking if these are Commandos, then no. 857 and 867 are model numbers. 1967 models. The 857 was the predecessor to the 1968 Commando 8 and the 867 was unique. The only 8 HP short frame/six-speed combo made in the 60s by Wheel Horse. Share this post Link to post Share on other sites
RCTruckDaddy 8 #3 Posted May 8, 2012 I just bought a 867 this weekend with a broken rod. Came with a complete deck with no holes. Is it supposed to have long axles on it? Share this post Link to post Share on other sites
Kelly 1,033 #4 Posted May 8, 2012 No the 867 has the standard axles. Share this post Link to post Share on other sites
RCTruckDaddy 8 #5 Posted May 9, 2012 Ok. Well someone has changed them. Share this post Link to post Share on other sites
Kelly 1,033 #6 Posted May 9, 2012 Is it still a 6 speed? Share this post Link to post Share on other sites
520HC 208 #7 Posted May 9, 2012 If you mean the hubs don't fit right next to the housing,yes they do come with long axles. Share this post Link to post Share on other sites
Kelly 1,033 #8 Posted May 10, 2012 The hubs will be about 1" or so from the trans case, in the 6 speed, the commandos had the long axles and the hubs are about 3" from the trans case but they are 3 speeds, those are what is commonly called the long axles. Share this post Link to post Share on other sites
RCTruckDaddy 8 #9 Posted May 10, 2012 Ok thanks. I'll check it again Dave Share this post Link to post Share on other sites
RCTruckDaddy 8 #10 Posted May 13, 2012 Ok I checked again. It is original. The hubs are about an inch or so from the case. Thanks Kelly. Dave Share this post Link to post Share on other sites
