mrc
tiller lift cable question
mrc
hi guys, i just finished fixing up an older C-series with a tiller for my friend RC. this C series was a 78 or 79. gas tank under seat kind of C series. the PO had a cable running from the mid rockshaft thru the tube above the unidrive. then it had a special long link with some links of chain which then attached to the tiller. lifting the tiller was possible but, heavy. i recently purchased an early C series with the gas tank under the hood. this tractor had a clevis hitch. it had the same type of cable but, it had a bellcrank? kind of thing which attached to a shaft in the support bracket that holds the fender and seat on. seems this would help with leverage??? i noticed that my 400 series tractors do not have the holes in the gas tank support bracket for this bellcrank either. so my question is: was this tiller hooked up properly to the 78 C-series or is there something i missed??? is there some way to make it easier to lift the tiller??? thanks mike in mass.
dennist
Mike, I will really be supprised if there are no holes in your 400 series for support for the bellcrank, as I have taken apart many and all have had the holes there. Maybe take the seat pan off and you will see the holes better. I have never used the tiller without the bellcrank, so no help there.
Kelly
As far as I know all the tank supports have the holes, I've tore lots of them apart and ALL had holes, I can tell you the early style bellcrank will not fit the newer tractors you need one for a tractor with the tank under the fender, the other one only fit the tractors with the tank under the hood with the soild mounted fenders, not the one the fenders flip up, so only 76-77 machines.
boovuc
To answer your question, no, the tiller really should be hooked up to a rockshaft as you noticed and not directly to the lift arm. I know folks do this but as you stated, it's heavy!
wheelhorse 1045
this was another way and had it that way for about 4 years with no problem DSCN0001.jpg
wheelhorse 1045
my tractor is older but it gives another idea and you can aslo use a lift spring for the tiller
mrc
hi guys, i laid on my back under my 400 series tractor with a good flashlight in hand. i can now see the holes in the fender support bracket a rear rockshaft hooks into. thank you all for your help!!! mike in mass.
