dlhirsch 0 #1 Posted April 30, 2012 I am looking for replacement front spindles. The Wheel Horse part numbers are 5630 and 5631. The Toro part numbers are 115425 and 115426. I recently replaced one but the front wheels are going different directions. Any suggestions where I might locate these parts? Thanks in advance. Share this post Link to post Share on other sites
AMC RULES 37,235 #2 Posted April 30, 2012 What model tractor are they for? Share this post Link to post Share on other sites
dlhirsch 0 #3 Posted April 30, 2012 It is a Bronco 14. I think the model is 1-0421. Share this post Link to post Share on other sites
rmaynard 16,589 #4 Posted April 30, 2012 Those spindles are common to many models. They can be found used on eBay, and new from many online and local Toro parts dealers. Share this post Link to post Share on other sites
dlhirsch 0 #5 Posted May 1, 2012 What should I search for? I have tried both the Wheel Horse and Toro part numbers on eBay and Google to no avail. Share this post Link to post Share on other sites
Lars 526 #6 Posted May 1, 2012 Hey try this http://www.rcpw.com/search/?quest=5630&search.x=17&search.y=8 Share this post Link to post Share on other sites
dlhirsch 0 #7 Posted May 2, 2012 Thanks ! I'll check it out. Share this post Link to post Share on other sites
dlhirsch 0 #8 Posted May 8, 2012 Is there a way to verify which spindle might be bent or tie rod before ordering a replacement? Share this post Link to post Share on other sites
Kelly 1,033 #9 Posted May 8, 2012 Center the lower steering shaft, the part the tie rods bolt to, kinda a triangle piece, center that so the bottom is square with the ground, then look at the wheels to see what one is not pointing forward. Share this post Link to post Share on other sites
dlhirsch 0 #10 Posted May 10, 2012 Thanks for the tip. I'll check it out. Thanks again. Share this post Link to post Share on other sites
mountainside 1 #11 Posted May 10, 2012 My charger had the same problem...I ordered adjustable tie rods for it...I know it will hurt the value but i like my front wheels toed in a little at the front..no more than a 1/4 of an inch though.. Share this post Link to post Share on other sites
