Dapper Dan 0 #1 Posted July 11, 2008 I've missed several good deals on 520's of late. I'm going to look at one Saturday that (from the pictures) looks very nice. Problem is it shows 1161 hrs on the meter. How many hours would you expect to get out of a well maintened 20 hp Onan? Share this post Link to post Share on other sites
Just Piddling 0 #2 Posted July 11, 2008 Others with more knowledge will be along shortly, but I'll tell you what I know. The major problem with the Onans are valve seats coming loose from being overheated. Check the cooling fins to be sure they are clear of debris and any other signs of overheating. A puff of smoke after choke is OK, but should not smoke afterwards. Mine has 850 hours and still strong. Good luck and where are you located? Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,834 #3 Posted July 11, 2008 Here is a similar thread in regards to the Onan engine: http://www.wheelhorseforum.com/index.php?...ic=3567&hl=onan Basically I don't think those hours are too bad, as long as it was properly maintained. B) Share this post Link to post Share on other sites
Curmudgeon 28 #4 Posted July 11, 2008 Onan's can last a long time, they are a good, strong running engine. However, parts are no longer being produced and the shelves are getting bare. If it ever needs work, you might be looking at a replacement engine instead. Without knowing the complete maintenance history of this machine, I'd say 1200 hours is getting up there. You just don't know. If it's cheap enough, I say go for it, it's a great tractor. Share this post Link to post Share on other sites
Rideawaysenior 28 #5 Posted July 11, 2008 Just wanted to pipe up and add my two cents. I have a couple of WH machines that use the Onan engines. A 518-H, and a D160. They both have a ton of hours on them especially the D160 being it's a 70's vintage. Both run great and strong. The only advice I can offer is what has already been said. Make sure the cooling fins stay clean and that you use a good quality oil. If you do that you may just be using the same machine in 30 or so years. Assuming that we can still get gasoline to run them. Jack Share this post Link to post Share on other sites
Just Piddling 0 #6 Posted July 11, 2008 You can look at it this way too. Even if the engine pukes, for the price of a mower at Lowes you can repower with a 24 hp honda and have a lot better tractor. I would be more concerned with the hydro. Make sure to operate it long enough to get the temp up and see if it still pulls. It all depends on the asking price Share this post Link to post Share on other sites
Dapper Dan 0 #7 Posted July 11, 2008 This machine was listed on ebay with a buy it now @1200.00 No offers and ended. Emailed the owner and he advised $950.00 was low dollar. Owner is about 90 miles from me. Here is the listing on e-bay. 520H What do you all think? Share this post Link to post Share on other sites
kpinnc 17,580 #8 Posted July 11, 2008 I would be more concerned with the hydro. Make sure to operate it long enough to get the temp up and see if it still pulls. It all depends on the asking price I agree 100%. Make SURE the hydro is a good one. You can re-power with a different engine, but the Eaton hydro is a little harder to find parts for, and possibly even MORE expensive... Kevin Share this post Link to post Share on other sites
Just Piddling 0 #9 Posted July 11, 2008 That looks like an 88-90 model (straight front axle). I wonder what the guage is in front of the speed control. Did they say why they pulled the listing and then offered you a cheaper price? Share this post Link to post Share on other sites
Dapper Dan 0 #10 Posted July 11, 2008 They didn't pull the listing. It ran for 7 days with no offers or "buy it now." Would this model be so old it would not have the gear reduction steering? Share this post Link to post Share on other sites
Just Piddling 0 #11 Posted July 11, 2008 Probably, but is not bad unless you put a loader or something on it . Mine is an 88' and I don't mind the steering. If you can get the number off the fender pan, we can tell all about it.Sorry for not paying attention to the listing. Share this post Link to post Share on other sites
DMESS 24 #12 Posted July 11, 2008 No gear reduction steering till 1991. The maroon stripe 520 is an 88 or 89. Share this post Link to post Share on other sites
HorseFixer 2,014 #13 Posted July 11, 2008 Onan's can last a long time, they are a good, strong running engine. However, parts are no longer being produced and the shelves are getting bare. If it ever needs work, you might be looking at a replacement engine instead. Without knowing the complete maintenance history of this machine, I'd say 1200 hours is getting up there. You just don't know. If it's cheap enough, I say go for it, it's a great tractor. Hey Dale I Hope Mine In My New Motor Home Lasts A Long Time! It Has 25 Hrs On It! Duke Share this post Link to post Share on other sites
Duff 206 #14 Posted July 12, 2008 Boys, did I miss something, or are we shockingly lacking in our manners????? Dan - Duff EDIT: OOPS! I misread Dan's date of membership. Oh well...sucks getting old. So......Welcome again!!! Share this post Link to post Share on other sites
Curmudgeon 28 #15 Posted July 13, 2008 Hey Dale I Hope Mine In My New Motor Home Lasts A Long Time! It Has 25 Hrs On It! Duke Duke, I hear the key to engine longevity is Amsoil. I'd check into that if I was you. Share this post Link to post Share on other sites
