Countdown To Christmas!
Electro12WH
Custom Dash Panel?
Electro12WH
I want to create a custom dash panel. I thought about using the steel backing plate and making a 22 guage aluminum plate to go over it, only cutting out the things I want. I'm only using the throttle/choke slots and the ignition switch. Has anyone else got ideas for the dash???
Keith
Sounds good to me.
73-18 automatic
Diamond plate aluminum?????
AMC RULES
:text-worthless:
massey
Just weld in whatever holes you are not using and have Terry make a custom decal for you.
Sorry I don't have a closeup of the one he made for me but it can be labeled however you want.
Electro12WH
Hmmmm.... That's a thought! or texture paint.
krazy_horse
Nice job,you gave me some ideas.
TT
I made one from aluminum..... but there's nothing in it other than the four screws to fasten it to the housing. B)
AMC RULES
Man, that's a cool tractor. :text-datsphatyo:
Electro12WH
Is there a trick to bending aluminum if you don't have a metal break?
AMC RULES
Heat, maybe? :dunno:
Anglo Traction
Electro12WH....I've sent you a PM
SousaKerry
Bending aluminum can be a challenge first you need the right grade most common grades do not bend well without cracking look for something in the 3000 series comon 6061 will crack. Without a break it is hard to do but can be done with a vise and clamps and bars.
JMW
bo dawg
Let us know how it turns out. We might want one if you can produce it easy enough.
Electro12WH
Anglo Traction sent me some very good intructions. Perhaps he will share.
JamesBe1
Anglo Traction, I would like to see the instructions also if you could send them my way.
James
Anglo Traction
James
Hi James, I've hooked you up to the PM I sent to Electro12 (and added some). Hope it helps.
oneroadkingman
yes i definitely like that too!!
