oneroadkingman 53 #1 Posted April 26, 2012 does anyone know if u can get replacement screws for the butterfly and choke plates.i took mine off to rebuild and while putting back together one broke off in the shaft a real bummer.sho now i am not sure what to do know ?thanks for your advise .. Share this post Link to post Share on other sites
joel_400 59 #2 Posted April 26, 2012 Last i got these was from Lakota racing in ohio. Not too expensive and they have a good selection of carb parts. If you cant find there contact info on the net let me know and ill get it to you. Joel Share this post Link to post Share on other sites
Duff 206 #3 Posted April 27, 2012 Or try Brian Miller's shop - he's got everything Kohler! http://gardentractorpullingtips.com/a1carb.htm Duff :thumbs: Share this post Link to post Share on other sites
bowtiebutler956 650 #4 Posted April 27, 2012 I don't know what carb you have, but I have an old Kohler 28 you can have. Came off my K301. I doubt it would cost much to ship. PM me if you want it. Matt :flags-texas: Share this post Link to post Share on other sites
Cole 25 #5 Posted April 28, 2012 the same thing happened to me when i rebuilt my k241, all i did was grind the screw flush with the shaft so i could pull it out and get the drill bit in the center of the hole, then i took a drill bit the size if the screw and drilled and tapped the shaft, then i went to an ace hardware store and went to the small engine repair in the back, told the guy what i needed he took me to the screw isle with the shaft and we found the screw, very cheap. The carb is like brand new again. hope this isnt too confusing and helps. :) Share this post Link to post Share on other sites
oneroadkingman 53 #6 Posted April 30, 2012 yes that's is what i thought too .i called a local repair shop and they told me that those screws were special and could not get them so i said what about drilling taping .he said i don't know if it would work ?i said alright then..and left. Share this post Link to post Share on other sites
