Pollack Pete 2,273 #1 Posted April 26, 2012 I'm looking for an ignition coil for a K-321 14 horse Kohler with breakerless ignition.I guess the part number is 236826-S.I've found quite a few online,but the price scares me.$165.00 to well over $200.00. I have an old NAPA catalog and can't seem to find this coil there.All I see is the coil for point ignition.Anyone here have a less expensive alternative for this coil? I'm having a hard time justifying a 199 dollar coil on a 200 dollar tractor.Thanks for any and all info. Share this post Link to post Share on other sites
oldredrider 2,553 #2 Posted April 26, 2012 The "cheap" fix is to convert it over to a points ignition. You can buy a LOT of points for the price of that coil. Share this post Link to post Share on other sites
pfrederi 19,802 #3 Posted April 26, 2012 Agree with above. Even if you get a coil then there is the possibility the trigger could be bad also more big bucks. You will need to change out you ignition switch get a coil, points, cover and plunger. The hole for the points plunger is in your block (filled with a welch or freeze plug. Share this post Link to post Share on other sites
specialwheelhorse 174 #4 Posted April 26, 2012 I couldn't agree more ! Way to go guys!!!!!!!!!!!!!!!!!!!!!!!!! Share this post Link to post Share on other sites
baerpath 517 #5 Posted April 27, 2012 Or stop by I have 3 or 4 spares. Take one and try it make sure it's the coil. Duane Share this post Link to post Share on other sites
