liketoplayto 6 #1 Posted April 23, 2012 Ok i know u only use brake in an emergency but this one wont bring back the hydro lever at all and my wife refuses to use it till i fix it hummmm no wait anyways need to know what mite be the problem it use to work but now the lever will not move back to nuetral from forward or rev thanks wes Share this post Link to post Share on other sites
kpinnc 15,730 #2 Posted April 23, 2012 Look under the center console plate, the one between your legs. There is a cam and follower on the left side (if seated on the tractor) mounted vertically. Depending on the model, it's usually under the brake set lever. If the cam has come loose, the DCL (direction control lever) won't be forced back to neutral when the brake is depressed. It's held in place by a single bolt, which can come loose and the cam will fall off. It only goes back on one way, so if that's it- it will be an easy fix. Share this post Link to post Share on other sites
liketoplayto 6 #3 Posted April 23, 2012 OK I WILL CHECK FOR IT. BUT WOULD THAT CAUSE THE EMERGENCY BREAK NOT TO SET EITHER ITS A 1989 MODEL OTHER THEN THAT IT WORKS GREAT I DONT KNOW WHAT HAPPENED TO IT BUT I WILL CHECK IT OUT AND SEE IF IT IS WHAT UR SAYING IT MITE BE. THANKS WES Share this post Link to post Share on other sites
Forest Road 594 #4 Posted April 24, 2012 That would do it. I just went through that with a 1989 model as well. I had to pull the side panel and manipulate the brake rod enough so I could drill a hole in the end. Then I had to reassemble and get a cotter pin into it. Took a little bit of time but not horrendous. Only way to get the brake rod completely out was to pull the hydro cylinder and I wasn't in the mood. Share this post Link to post Share on other sites
liketoplayto 6 #5 Posted April 24, 2012 GOT IT FIXED THANKS BOTH OF U FOR ALL UR HELP TOOK ROD OUT AND RE DRILLED HOLE I JUST DISCONNECTED BRAKE ROD FROM THE SPRING IN THE BACK AND MANUEVERED IT OUT REDRILLED AND MANUEVERED IT BACK IN AND PUT A COTTER PIN IN IT AND ADJUSTED THE BRAKE SPRING WHEN I HOOKED IT BACK UP THANKS U GUYS MUCH APRECIATED FOR ALL YOUR HELP THANKS AGAIN WES Share this post Link to post Share on other sites
