BairleaFarm 340 #1 Posted July 10, 2008 Can you cut the back off a sd deck and weld up the side and make it a read deischarge? Id like one and Ive got a SD but the rear is rusted out of it. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted July 10, 2008 I don't see why you couldn't do it. You just have to make sure the gauge wheel cross shaft and height adjuster parts don't get in the way. You could also leave it all closed in and have a mulching deck. (You'd probably want to buy some Gator Blades for on it then.) Share this post Link to post Share on other sites
BairleaFarm 340 #3 Posted July 10, 2008 I figured there wasn't anything different other than the opening. A mulching deck might not be a bad idea either Share this post Link to post Share on other sites
DMESS 24 #4 Posted July 10, 2008 I second building a mulcher. A lot less work and nicer results mowing. (unless your always trying to cut 4 inches of grass at a time) You would only need to fab a blocker plate for the chute and, as TT mentioned, add some good mulching style blades. FYI, they did offer the factory Recycler kit for the 48" SD. Share this post Link to post Share on other sites
BairleaFarm 340 #5 Posted July 10, 2008 I think ill try the recycler before ill cut the back out. Share this post Link to post Share on other sites
nylyon-(Admin) 8,124 #6 Posted July 10, 2008 I take my "Recycler" off in the spring. The Recycler cloggs very easily with wet or even damp grass. The grass here is still too wet to put it back on again, maybe in a couple of weeks I can get it back on there. This year has been very busy, I have let the grass grow too long. The RD deck with a sweeper pulling behind does really quick work of cleaning up the "harvest" Share this post Link to post Share on other sites
DMESS 24 #7 Posted July 10, 2008 karl, how high or low do you cut with your Recycler? Share this post Link to post Share on other sites
nylyon-(Admin) 8,124 #8 Posted July 10, 2008 As high as it will go. Share this post Link to post Share on other sites
DMESS 24 #9 Posted July 10, 2008 Hmmmm, I'd like to try the Recycler kit, but I don't want to deal with clogging problems. Of course, your grass and mine are two different things. I've got a dust bowl right now! B) Share this post Link to post Share on other sites
dgjks6 8 #10 Posted July 10, 2008 I keep seeing a recycling kit for a 42 inch deck on ebay. I think it consisted of a second set of "baffles" - the round things under the deck - so each blade was completely enclosed in a circle. Does that make sense? Share this post Link to post Share on other sites
nylyon-(Admin) 8,124 #11 Posted July 10, 2008 Dustin, Eldon has one maybe once it is repaired you can test it. As far as the kit on eBay it is incomplete. Inside those round things, there should be triangular baffles, 3 in each one. Also, to use the kit you need to have a 42" deck without any baffles already. Share this post Link to post Share on other sites
DMESS 24 #12 Posted July 10, 2008 That's really all it is. The baffle plate, unique blades and of course the mounting hardware. EDIT: and what Karl said! Oh yeah, Eldon and I have discussed that deck. It's a back burner project right now you could say. Share this post Link to post Share on other sites
