unsub 0 #1 Posted April 21, 2012 The throttle on my 314-8 won't stay at at max speed. It wants to vibrate itself back off to about 75% after a couple minutes. I've been keeping it at full throttle with a bungie cord, but I'm sick of doing it that way. The cable seems to move fine and smooth but just won't stay at 100%. Anyone else have the same problem or have any ideas on a remedy? Thanks. Share this post Link to post Share on other sites
rmaynard 16,699 #2 Posted April 21, 2012 Sounds to me like the rivet that the throttle control pivots on has loosened. I had the same thing on a C-series. The throttle control stays in place by friction, and if the center pivot gets loose, the arm will eventually slide down. You may have to take the cable control out and lightly peen the rivet with a hammer and punch. Share this post Link to post Share on other sites
unsub 0 #3 Posted April 21, 2012 Sounds to me like the rivet that the throttle control pivots on has loosened. I had the same thing on a C-series. The throttle control stays in place by friction, and if the center pivot gets loose, the arm will eventually slide down. You may have to take the cable control out and lightly peen the rivet with a hammer and punch. You're right. I peened it a little and it sure seems to have done the trick. Worst case I guess if it does it again is to replace that part. At least I know the culprit. Thanks a million. Can't believe I used the bungie all last season. Share this post Link to post Share on other sites
can whlvr 994 #4 Posted April 21, 2012 some one here stated before that they replace the riet with a small bolt after the peening doesnt work anymore Share this post Link to post Share on other sites
tunahead72 2,591 #5 Posted April 22, 2012 Can't believe I used the bungie all last season. Only one season, that's not bad! You can also try squeezing the rivet with a pair of vice grips, without having to remove the entire throttle control from the tractor. If it doesn't help at first, tighten the vice grips a little and try again. And :WRS: Share this post Link to post Share on other sites
btrrg1969 11 #6 Posted April 22, 2012 some one here stated before that they replace the riet with a small bolt after the peening doesnt work anymore I didnt state it but thats what I did , drilled out the revit and use a 1/4 bolt and lock nut , that fixed the problem Share this post Link to post Share on other sites
unsub 0 #7 Posted April 22, 2012 :thanks: More great ideas. Thanks again guys! Share this post Link to post Share on other sites
boovuc 1,090 #8 Posted April 22, 2012 Here is an idea that you don't want to do. My C-175 has been using the bungie cord fix for ten years. About a decade ago, the throttle cable was real tight and was "sticky" so I put spray oil and silicone to it. That took care of the tightness! It has never ever stayed wide open after that! It always drops back to about 60% open. Not peening or squeezing got it corrected. I was half tempted to apply some battery acid to it to re-corrode it! Since this is a worker tractor, the bungie cord is OK! Share this post Link to post Share on other sites
can whlvr 994 #9 Posted April 23, 2012 i too have used a bungie,after about 2 years i broke down bought a new cable then learned about these fixes,at least i saved the old cable so i can reuse it Share this post Link to post Share on other sites
