Monkalunka 7 #1 Posted April 19, 2012 Hello again, looking to start up the motor on the barn find. I dont know anything about it other than it i free. I would like to see if she will run. what should I do prior to starting. Rooster was kind enough to send me a 300 page manual but I hope someone can give me some quick tips to give her a shot to fire up. Thanks a bunch Chris pics if you need them are in my gallery Share this post Link to post Share on other sites
CRE1992 143 #2 Posted April 19, 2012 I would check the oil level, clean the spark plug, clean the carb, clean or replace the points and condenser, add some fresh gas and give it a pull! Share this post Link to post Share on other sites
Kelly 1,037 #3 Posted April 19, 2012 Do not use starting fluid on small engines, I use brake clean, I'd drain the oil and put fresh in it, check for spark, if none clean the points. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #4 Posted April 20, 2012 Just to add to what has been said already.. 1- change out the fuel line with new. 2- install an in line fuel filter. 3- make sure the tank is clean without rust etc. if rust is present pull the tank throw a piece of chain in it with degreaser and water and shake it reall good for a while and then wash it out good. if you have way to blow it out with air do so if not you will have to wait until it is dry, add new gas and fire it up. Share this post Link to post Share on other sites
Ken B 3,202 #5 Posted April 20, 2012 If you get it running before you try riding it don't forget to check to see if there is any fluid in the differential. They tend to leak out over the yrs. Share this post Link to post Share on other sites
Monkalunka 7 #6 Posted April 20, 2012 thanks for the advise all...I really appreciate it Share this post Link to post Share on other sites
wheelhorse656 20 #9 Posted April 20, 2012 I add a teaspoon of oil to the cylinder and slowly crank it over about 10 times. That being added to all the steps mentiond before. Share this post Link to post Share on other sites
bowtiebutler956 650 #10 Posted April 20, 2012 I'd say these guys pretty well covered it. Matt :flags-texas: Share this post Link to post Share on other sites
Matt Baumgardner 4 #11 Posted April 28, 2012 I also have the same type of engine and was wondering if you might be able to answer a few of my questions? Share this post Link to post Share on other sites
bowtiebutler956 650 #12 Posted April 28, 2012 Matt Just go to the engines section, and on the right hand side you will see a button that says Start New Topic. Hit that button, and ask all the questions you want, or you could post it in the introductions section being your new here. That's a great name you have! Matt :flags-texas: Share this post Link to post Share on other sites
