carlsbarn2 7 #1 Posted April 18, 2012 I want to put 26x12x12 tires on my C-175. What is easiest way to get fender clearance and keep deck from hitting when in reverse ? If I put spacer under fender assemble,my gas cap sits too low to open,I really didnt want to start cutting fenders & deck . Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted April 18, 2012 I put a 3/4" spacer under my fenders to raise them, I can still get the gas cap off no problem, and I used 10" wide rims so the tires are flat not bowed up in the middle, I'm not sure you will be able to use a deck on it with that size tire, I would guess the deck wheels will rub the tires. Here is my 520 with 26x12x12's Share this post Link to post Share on other sites
1maidenfan 202 #3 Posted April 18, 2012 Nice tractor Kelly :text-datsphatyo: Share this post Link to post Share on other sites
Sparky-(Admin) 23,797 #4 Posted April 18, 2012 You may have to run a 36" rear discharge deck on your 520 with those tires.... . A 36" deck on a 48" wide tractor ! Mike................ Share this post Link to post Share on other sites
carlsbarn2 7 #5 Posted April 18, 2012 When I put spacer under fender,my gas cap stays low.Im I missing something ? Share this post Link to post Share on other sites
Kelly 1,033 #6 Posted April 18, 2012 Yes my cap is low, but I can still get it on and off, I did use a cap off a MTD with out the gauge, my 520 has the guage on the dash. Share this post Link to post Share on other sites
