pgbryant 0 #1 Posted April 16, 2012 I need help finding a replacement rear wheel. I have a Wheel Horse zero turn radius mower. The numbers on the model and serail plate are Y1160E01 25987 9104. The rear wheel has a 1 inch keyed bore. It is an 8 inch rim. The key sheared and tore up my wheel before I noticed. Thank you for your help! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,874 #2 Posted April 16, 2012 Your 616-Z model number is written like this with a dash Y1-16OE01. The 1st O is a letter for Onan engine. The 2nd 0 is a number. That is the only model and year to use a part # 117145 wheel which has been discontinued by Toro. Tire size is listed as 18 x 9.50-8. Garry Share this post Link to post Share on other sites
pgbryant 0 #3 Posted April 16, 2012 Thank you Garry!!!! Does anybody have any idea if there is a replacement wheel that may be used for part #117145? Are there any used wheels out there? Phillip Share this post Link to post Share on other sites
Buckshot 1 15 #4 Posted April 16, 2012 If the keyway in the axle is ok. Dismount the tire and take the rim to a machine shop and have them put a new keyway 180 degress from the bad one. Of course this all depends on how bad the rim is tore up. Don B. Share this post Link to post Share on other sites
