Stigian 1,234 #1 Posted July 9, 2008 Evening all, one of the jobs i have been wanting to sort out for a while now is to stop my wheel weights/duel wheel adapter 's from rattling. Rattling you ask? well when i built them i filled them up with a dry-ish sand, cement and stone mix, the idea was the moisture in the stones and a bit of condensation forming would set the mix hard over time. Can you guess what didnt happen Over time the dusty stuff found its way out leaving space for the stones to move about Time to sort it out Step 1 - Use large rubber hammer to remove the weights from the wheels and wonder if a mouse has built a house in the wheel. Step 2 - Laugh and take photo of 4 balls of grass that fell out Step 3 - Dump both weights on the bench and wonder how they got so dented Step 4 - Break out the hole cutter and try to break in to the weight. Step 5 - Wonder why after 5 minutes of drilling ive not broken in to it yet Step 6 - Have a look at the hole cutter teeth to find this Step 7 - Put the new (well it was before i started) but knackered hole cutter back in its case and make some sparks with a grinder Step 8 - Empty the loose contents of the wheel weight all over my boots and legs Share this post Link to post Share on other sites
Stigian 1,234 #2 Posted July 9, 2008 Step 9 - Stop coughing from Step 8 just long enough to wonder how Garry managed to get a small Ford Pick-up pierced through his neck on the way back from getting a barrow load of sand Step 10 - Drink some water (not coffee ) to stop the coughing and take an action shot of Garry mixing the mix. Step 11 - Look daft while laughing at using an old lampshade as a funnel Step 12 - Stand back and look at the mess we have made Step 13 - After letting the new improved wheel weights set for a few day (an ideal time to try and wash out all the metal grindings/dust/cement/sand/concrete mix that has set/got into hair/ears/armpits/add body cavity to taste/perversion ) clean off the the muck so the square-ish plates that were cut out can be welded back into place. Step 14 - Forget to take photo of the finished wheel weights but if you imagine sqaure-ish plates welded on and lots of dents on this early pic then your close And........ Step 15 - Hope the wheel weights will fit back on the wheels when i come to put them back on B) Share this post Link to post Share on other sites
kj4kicks 154 #3 Posted July 9, 2008 As usual, great pics and well narrated ! Thanks for making me smile.... :whistle: Share this post Link to post Share on other sites
combatmp29r 27 #4 Posted July 9, 2008 Excellent work Ian. A pleasure to read as always B) Share this post Link to post Share on other sites
CasualObserver 3,410 #5 Posted July 9, 2008 Took me a second there on that last pic... i thought maybe you actually made invisible seams! But rest assured... I can see the dents and squares (in my head) now! B) Share this post Link to post Share on other sites
DMESS 24 #6 Posted July 9, 2008 :whistle: I hope Gary got that pick up out of his neck! Good laughs as usual Ian. B) Share this post Link to post Share on other sites
Curmudgeon 28 #7 Posted July 9, 2008 Keep us abreast of how it comes out, Ian. Don't feel too proud of those grass nests though, they seem to accumulate behind any kind of wheel weight, but I'll never admit to that disadvantage of them. Share this post Link to post Share on other sites
Stigian 1,234 #8 Posted July 14, 2008 Cheers for the great comments guys The good news is not only did the wheel weights fit (just), but we also managed to get the pick-up out of Garry's neck. I just put it in reverse and floored it B) Share this post Link to post Share on other sites
